Home › Forum › Ask A Member › Help identifying Sears boat year
  • #4416
    wyo307
      Last night I acquired an old aluminum Sears boat to use my small outboards on. It has a identification plate but doesn’t have a HIN NUMBER SO IT MUST BE PRE 1974? Anyways the plate reads
      Model number: 581-61102-0
      Serial number : IS27F 1216
      Does anyone have an idea of what year this little guy is? I will need to know when I go to have it registered.
      I also got a 1971 evinrude sportwin 9.5 hp with the metal tank with it so I think I did pretty good.
      Thanks for the help
      #37557
      ladler
        Are you sure you don’t have any numbers turned around on the serial number?
        #37560
        wyo307
          I’m pretty sure
          #37593
          david-bartlett
            Did you check the outside of the transom on the Right(starboard) side. Could be stamped into the metal, and thus no obvious tag.
            #37828
            wyo307
              quote david bartlett:
              Yes I did the tag that I posted a picture of is the only identification on the hull
