Home › Forum › Ask A Member › Help identify old merc
Viewing 10 posts - 11 through 20 (of 23 total)
  • #291329
    Jason Chisholm
      The holes for the mag advanced are not drilled.
      Jason chisholm
      #291330
      CHUCK
        Ah;  OK….I missed the H earlier.
        Serial_H
        #291338
        fastjohn
          AJ 29 came on KE-7 and KF-7
          #291339
          Jason Chisholm
            I thought Ke7 and kf7 have a sand cast block with no serial number I might be wrong on that.
            Jason chisholm
            #291340
            Jason Chisholm
              At least not on the block
              Jason chisholm
              #291343
              Jason Chisholm
                I tried to look up serial number but it should be only 6 number instead of 7 if it was a kg4 unless it’s not a 1953. Or the out of place 5 shouldn’t be there. So I am clueless didn’t the marks change shape on the bottom front it went flat without the point
                Jason chisholm
                #291350
                Jason Chisholm
                  Hey if you think more pics would help let me know n I’ll try to put them up.
                  Jason chisholm
                  #291352
                  Jason Chisholm
                    Don’t know if this matters but these are the plugs in it. I used a jeweler loop on the serial number and each number has a double like they stamped it twice . Until someone more knowledgeable then me chimes in I think it’s a Frankie motor of a kg4h some just threw random parts on. The owner before me must have painted it or tried to looks like in the past 10 years someone was working on it fuel hose isn’t petrified plus I think it should of been copper
                    Jason chisholm
                    #291354
                    Jason Chisholm
                      Forgot photo
                      Jason chisholm
                      #291356
                      Jason Chisholm
                        Is there a way to edit old post I’m not computer smart
                        Jason chisholm
