Home › Forum › Ask A Member › Help Identify brass Props
  • #305144
    Can anyone I.D these ? …..Thanks
    #305170
    green-thumbs
      Right Hand Props  so they are not Mercury.  Possibly Michigan  Wheel aftermarket.
      Louis
      Follow  up question,,,  Do they seem to be for low power low speed outboards? Pat Pend seems to imply they are possibly pre WW2 or even , Bore size might narrow field of possible applications, Columbia , Michigan Wheel catalogs may give answer, It is possible to look up patent number on line if either prop is so marked. Information on props not 100% clear in photos, Could you transcrive and post?
      #305212
      [postquote quote=3 Only the shiny one has sharp edges and Pat Pending with 888 on other side. the dull prop is thicker with more blunt edges and no markings/numbers on it. .
