Home › Forum › Ask A Member › HELP 4HP Mercury problem
  • #7144
    joellerich
      I have been working on a Mercury Model 40, 4HP ser # 3303202 I think it is a mid 70’s engine. CANNOT GET THIS THING TO RUN FOR MORE THEN 30 SEC TO 1 MINUTE, Here is some data I have collected and the repairs made to date.
      Compression 110 psi
      Very good spark
      measured intake vac and pressure at the fuel pump connection reads +/_ 10 psi using a drill motor to spin engine w/o plugs
      requires full choke to get it to run the 30 sec.
      Repairs:
      New top and bottom engine seals
      Repaired fuel pump
      New water pump
      Clean and overhaul carb
      ANYONE GOT ANY IDEAS WHAT TO TRY NEXT ? TO ME IT SEEMS LIKE A INTAKE VACUUM PROBLEM.
      John
      #58469
        If you disconnect the fuel pump hose to the carb,
        is it actually pumping gas when you’re spinning over
        the engine?
        I rigged up a gravity feed tank once to bypass the fuel
        pump on one motor, and it ran good, telling me
        I had a vacuum / fuel pump problem.
          Check the float needle and seat. If it is still the original set up, it will have a metal point needle and rubber SEAT. (Due, I suspect, to Mercury’s propensity to do EVERYTHING opposite of OMC.) Anyway, the rubber seat can swell to make its effective opening very small. Thus you can fill the bowl, the engine runs but the fuel can’t reenter the bowl as fast as the engine uses it. Solution is to replace them with new ones, that are rubber-pointed with a metal seat, like normal humans would make. Just one thought. I have seen it.
