Home › Forum › Ask A Member › HD25 Cylinder Head
  • #4327
    jvinnbtx
      Is there a proper way to free the cylinder head from the crankcase cover on an HD25?
      #36901
      Leon
        Gently rapp it with a rubber mallet
        #36907
          Make sure the taper pins are out first. As the name suggests, they are tapered. You have to knock them out in the proper direction.
          #36910
          oltimer
            quote FrankR:
            Frank, your thinking of the crankcase cover; there are none in the cylinder head. Two separate components; and I believe he is talking about the head with the spark plugs in?
            #36912
              That’s what I thought also. But he said cylinder head to crankcase cover. Of course we both know that’s incorrect. So we really don’t know what he’s trying to get apart. I assumed cylinders from crankcase cover, but of course it wouldn’t be the first time I guessed wrong.
              #36918
              jvinnbtx
                Guys, Thanks for the reply – I think removing the taper pins – didn’t realize they were tapered – will allow me to get it loose.
                Thanks much, Jim
                #36921
                  When you put it back together, install the taper pins before tightening any of the screws. The pins ensure perfect alignment of the main bearings halves
                  #36926
                  jvinnbtx
                    Frank,
                    Thanks much. Knocking out the pins did the trick. The crankcase cover nearly fell off the cylinder housing (sorry about the earlier confusing reference to the head.)
                    Jim
