Home › Forum › Ask A Member › HD-25 float replacement
  • #237992
    Jim Brizzolara
      The carb float in HD-25 is shot. I could make a new one out of cork, but the dope to seal it would cost more than a Mercury plastic float, which I read can be used. On the Poche website he mentioned that the Merc float would have to be modified. Does anyone have experience with this?
      #237993
        folks here will tell you they work fine but you need to drill a center hole for the pin and clip .. never done one myself but if the Merc float is the same diam. no reason not to work
        #238014
          The Merc floats work great and I have installed several in my TN motors. The small spring in them has to be removed and then I drilled them out to get a friction fit on the needle. With a friction fit, the float level can be easily adjusted.
          DSC00008
          #238019
          aquasonic
            It’s been a while since I worked on an HD, but isn’t the HD float a smaller diameter than the TD/TN float?
            Improvise-Adapt-Overcome
            #238021
            Jim Brizzolara
              I think you’re right. The Merc part number I have for the float is a different number than the one in the picture. Thanks for the replies.
              #238084
              aquasonic
                I’m thinking that the TD/TN float is 1 1/8″ diameter, and the HD float is 1″ diameter, but not exactly sure. Is there one Mercury float for the “T” series, and a different one for the “H” series?
                #238095
                  are those floats solid core ?? or empty
                  if solid maybe you can spin it down to 1” over sand paper ??
                  • This reply was modified 5 years, 6 months ago by JACQUES.
                  #238098
                    Whoops, didn’t even think about the different OD’s. The part number shown in my earlier photo is the current P/N for the one in this older photo.
                    Mercury-Johnson-Floats
                    #238101
                    LLOYD LAUTNER
                      TD/TN floats are 1 3/16 diameter and 1″ tall. HD float is 1 1/16 diameter and 3/4″ tall. I would make one from cork and seal it with old time acetate dope, but whatever makes you happy and floats your cork.
                      #238108
                      Jim Brizzolara
                        I found a large cork, Superglued it to a large screw head, and sanded the cork to size in my drill press. I sealed the cork with Seal-All, which in my experience is very fuelproof. Thanks for all of the assistance, I’ll hopefully try out the motor today.
