Home › Forum › Ask A Member › HD-25 and TS-20 Lower Unit Seals
  • #233586
    skier167
      Hello,
      I’m moving along in my restorations of a HD-25 and TS-20. These are my first older outboards I’m restoring with the HD-25 being the first of the two. I’m working on seals for the lower unit/gear case and was wondering if there are any current model gaskets/seals for them? I have the prop shaft seal (Sierra 18-2035) but I’m looking for 43-300,687 and 43-301,975 I believe for the prop side of the gear case. I have gasket material to make my own but wanted to pick everyone’s brains before I go that route. Thank you for everyone’s help.
      #233609
        The 301-975 part shows up as a spring, so I’m guessing that the driveshaft seal under it (300-687) is probably a leather seal,
        but I may be wrong. If it’s leather, you’ll probably have to make your own. I would not look for old stock gaskets…….
        probably not in good shape by now. Dealers probably have sold parts for that motor in 45 years!
        skier167
          Thanks. I can’t tell if it’s leather or rubber. I know once made a tool to remove that seal but what else can be used? I attached some pictures of it but can’t tell which material it is.
          38E443BD-2414-42A6-9B9A-8B37B5632D04
          0D12CF73-DCCD-44AE-970E-40297740D3B7
          E4E35CC3-3BC9-4323-995E-AF2ED6EFFE64
          • This reply was modified 5 years, 8 months ago by Mumbles.
          #233650
            It’s been quite a while since I worked on mine, but I’m thinking the seal is leather,
            and yours looks intact, and it might be best to leave it alone.
            Those old gearcases used grease that was designed with water ingestion
            in mind. Even if you were able to put a modern lip seal in there, the driveshaft
            is likely to be pitted or grooved and the new seal would leak anyway.
            Perhaps someone in the know will give you better advice.
