Home › Forum › Ask A Member › Have a question on Hp and a 10’ wetback Hydroplane
  • #205123
    Daniel Pope
      Looking for info on horsepower and a wetback 10’ hydroplane
      #205124
      CHUCK WEBSTER
        I ran a 20 conversion on one I had in the late 70s. Worked ok.
        #205126
        David Stanton
          My take on hydroplane HP is that as long as it can take the weight of the motor, and the transom can stand the stress; it depends on how close to the edge you dare to be.
          Have fun!
            Class A – B motors are fine.
            #205128
            A. Hoskins
              I totally agree with Dave that motor weight is the key. On a Wetback I think about 100 lbs. of motor is the absolute limit. Use a short drive shaft housing to keep the center of gravity as low as possible. Volumes have been written about the relationship of the prop and prop shaft to the bottom of the boat. A lot of it depends on what you have for a prop.
              Certified JB weld
              #205149
              Daniel Pope
                Thank you much for your reply
                I’m sorta fishing to see if a 10 Merc would power that 9’8” wetback with my 9 year old Granddaughter.
                #205151
                  what yr would it be. the best would be a green tank super ten. a full gear shift would be OK especially to start with. not as fast .
                  #205153
                  Daniel Pope
                    It’s 30 years old. Runs like a wrist watch and starts 1/2 pull every time.
                    #205154
                      should be fun for him. work on props and engine height . start with cav. plate even and parallel with the bottom.
                      put a safety shutoff switch on for sure.
                      • This reply was modified 6 years, 5 months ago by DAVID.
                      #205156
                      Daniel Pope
                        My friend thanks for all that. That Wetback will be solid as a rock. Defiantly getting a safety kill switch. Intend to use a jack plate for up and down fine adjustments. Just hope it’s not too underpowered?
