Home › Forum › Ask A Member › Happiness is:
  • #1125
    mr-asa
      Clearing the garage out so I can actually use it, then having (almost) everything primered and ready for paint.
      What stage of project got you feeling satisfied recently?
      And because it has been running through my head all day…
      "Bang bang, shoot shoot"
      #13470
      Doug Wilson
        getting magneto back together with good spark on both cylinders the first time. Ready to prime lower unit on another project now too.
        Doug
        Doug
        turned off?
        #13471
        beerman57
          2 OMC 10hp blocks all cleaned up and ready for rebuilds. The QD19 is getting conn. rod with bearing upgrade. The 1962 is a fresh/used block, the original block is junk.
          #13472
            Successfully removing the internal rust from some pressure tanks!
            The first step in restoring some tanks is completed!
            #13479
              Room for more motors … 😀
              #13491
              gjonz
                Picking up a Golden Pennant-styled Corsair by Scott Atwater for 30.00.
                Then getting it home to find out my 5hp Corsair was actually a 10hp!
                Aha! That’s why it seemed so heavy!
                Greg
                #13500
                  Made some great progress on a 77 15hp and a 40hp Bigtwin gearcase last weekend.
                  #13504
                  Steve D
                    Having motors start on the 2nd or 3rd pull after all the work you put into them. Picked up these 2 last year, both not running at the time and didn’t get around to working on them until last month. Went through the ignitions, carbs, lower units, and broken handle assembly on the Evinrude. Caught a nice day last week and put ’em in water and both started real easy and smoothed out real nice after the carbs were dialed in. That made me real happy!
                    photo upload
                    #13509
                    mr-asa
                      quote Garry in Tampa:
                      Little lady found a home in foreclosure that is on about 2 acres, and has a hobby shop on the property. The shop is big enough for 5-6 cars and comes with a hydraulic lift in it already.
                      I drove by it and liked it until the train went past just past the back yard.
                      quote Steve D:
                      photo upload
                      I have a 5.5HP that I need to check out. It runs, but only at WOT. I’m thinking there’s a carb issue.
                      I like the updates, guys!
                      #13525
                      makeitrun
                        Taking all this and getting it to run again fired up on the second pull.
                        New lower seals/impeller, replaced crank , connecting rod and piston.
                        Reason for rebuilding
