Home › Forum › Ask A Member › Handy Taps And Dies To Have On Hand
  • #178657
      Here’s some common and not so common taps and dyes I keep nearby when working on the smaller OMC classics. While everything is apart, I like to chase all of the threads to remove any gunk or corrosion. That makes it a whole lot easier when going back together. The 4-40 is used for carb butterfly screws while the common 10-24 is used mostly for exhaust covers, intake manifolds, and mag plates. The 6-32 will clean up the threads on the mags adjusting screw for the points. The special order oddball 12-28 is used for the tiller grip screw and 1/4-40 is used for most carburetor mixture adjusting screws. The 12-28 comes in real handy as lots of tillers I see have mangled threads in them.
      DSC00013
      • This topic was modified 7 years, 4 months ago by Mumbles.
      #178668
      Randy in Tampa
        I use many of the same ones on the older Johnson motors “square tankers” Thanks for sharing Mumbles
        Rotary valve Johnson’s Rule!
        #178671
          Pretty sure I don’t have a 12-28 tap or die….. mine probably get
          retapped a different size without me knowing about it!
          rmhxruss
            Some OMC carb butterfly screws are 5/40 thread. A not so common size.
            #178682
              Mumbles – you are so right regarding having all of these taps and dies. I recently had to go pick up a 4-40 to clean up one of the carb butterfly screw holes when I rebuilt my RD-18 carb. I needed the 12-28 tap on another rebuild and although I didn’t have one, I was able to borrow one from a neighbor who was a machinist. Always good practice to clean up threads during the rebuild process.
              1982 Evinrude 25hp
              #178683
              amuller
                Thanks! Suggestions on a good source to order from?
                #178684
                  Great advice, will have to find the 12-28 and 1/4-40 ones for sure…
                  #178687
                  Geer Pyron
                    Living in a small town I have a problem finding certain tools. Tried to going to the local machine shop, but they just grunted at me.
                    I mostly have to order them from the innerweb.
                    My go to is Mcmaster-Carr.
                    They have everything we need.
                    If you don’t mind shopping online.
                    g
                    JMGP
                    #178689
                      I’m in Victoria and no one here could supply me with them so I had to mail order them from a tool supply house in Vancouver. !/4 – 20 left hand thread for an ongoing project are next.
                      #179181
                      Thomas Otto
                        Fortunately my wife’s grandfather was a Singer Sewing Machine repair man (person for CA) and she (I) has inherited his machinists tool box that has a wide variety of taps and dies. I also have my great grandfathers machinist tool box. Tom Weatherston worked in the machine shop for Pierce Arrow in Buffalo, NY. Oh, the things these two gentlemen must have known and seen…
                        I will need to go through both boxes and “liberate” the tools that are most commonly used for my small collection of antique outboard engines.
                        Thank you for the list Mumbles!!
