Home › Forum › Ask A Member › HA39 Primer
  • #3385
    GARY
      Re-installing primer.The pins in the shaft are the issue.Are the pins inside the cup when it is installed or does the spring "thread" onto them?When I took it apart the spring was threaded onto the pins and the cup was convex end up and slid down over top of spring.First pic shows pins and what I assume is proper order.Second is how it was installed.
      aquasonic
        Stanley…The top picture is correct…The bottom picture shows a common mistake with the brass cup. Hopefully, you have the thin washer that sits atop the upper pin and gets put on from the top.
        Improvise-Adapt-Overcome
        #30106
        GARY
          Thanks,Yes I have the washer.Just got new leather washers from Mr Lautner and want to get this diabolical little carb back together.
          #30112
          aquasonic
            Here’s a handy diagram:
            #30113
            GARY
              Thanks,had that pic and lots of others,but none show the pins through the shaft.Re-assembled after your reply and all makes sense with brass washer in place and pins inside cop to hold it up
              #30115
              aquasonic
                Anytime…Earlier I could see your two pictures, but they are blank now when I try to view them. Maybe this computer is blocking them?
                Edit: a reboot fixed that. I see them now!
