Home › Forum › Ask A Member › grease fitting holes
  • #8273
      Johnson 1929 7.15hp Model K-45
      It has one large screw fitting for grease to go in. Where is the outlet hole located.
      chuck86
      #65160
      Leon
        Can you by chance post a picture of the hole you’re referring to? This way, we can give you a more detailed analysis
        #65179
        George Emmanuel
          Look on the underside of the propshaft bearing holder, the cone shaped part before the propeller. You should see a small plug with a slot for a screwdriver. (I am not referring to the screw that is 90 degrees to the prop shaft that is a thrust bearing locator). Grease goes in there and comes out the larger hole. The larger hole’s also for inspection, meaning you can remove the plug and see if there is grease in the gearcase. Normally the design is such that grease goes in from a lower position so gravity allows it to gather and push out thereby filling the void rather than the reverse which would be run out and creating a void.
          George
