Home › Forum › Ask A Member › Gopher Lower unit picture
  • #7727
    hotrod
      Gopher lower unit picture. (Couldn’t add a picture in ‘reply’ mode).
      You should try heating the area of the casting between the pump cam and prop area. And lube it.
      #62210
      2fast4me
        Hotrod, thanks for the pictuses. I was able to get the shaft to turn inside the lower unit, I did not try pulling the shaft from the casting yet. Now that I have your picture I will proceed with caution. I might have a piston inside the LU, im still looking.
        Thanks again. You have been a big help.
        Jim
        2Fast4Me
