Home › Forum › Ask A Member › Good replacement material for these gaskets?
  • #1622
    mr-asa
      56 Fastwin
      203355, low speed idle packing nut washer, and the o-ring for the glass fuel bowl. It looks like rubber (what type though?) was used for the first and cork for the second?
      #17090
      RICHARD A. WHITE
        Can you be more specific? as in what hp of motor?? 1956 15 hp if so for the fuel filter bowl Marine Engine says this is your gasket:
        And the carb low speed packing nut is the same as I posted earlier….18-7106
        http://www.marineengine.com/newparts/pa … &submit=Go
        classicomctools@gmail.com
        #17094
        mr-asa
          Yup, 15hp. 15016 serial if I remember correctly.
          I am not looking to buy a new bowl gasket, I want to try and avoid the costs of that if possible, shipping and handling, price of it, why do that if I have materials that will work? I am fairly sure I have something sitting around that does.
          And 18-7106 is the packing washer. I am looking for the packing nut washer, #203355. Rough dimensions (before it broke) were 1"OD, 1/2" ID, 1/16" thickness. I believe it was made of rubber. Most definitely not the packing washer that seals around the idle needles, this guy seals the hole created where the low-speed screw goes through the silencer
          #17117
          mr-asa
            Item #76 is the packing nut washer
