Home › Forum › Ask A Member › Gift from my boss .. Lightwin
Viewing 10 posts - 41 through 50 (of 61 total)
  • #220553
      just cut up one of those sticky pads to size and put the felt side on the cam lobe.
      #220554
      Samuel Phelps
        The points came with new felt ..
        #220565
        cajuncook1
          Cool! Just clean up what ever grease you applied to the point shoes and cam. Don’t want that potentially fouling up the points later on. The light oil on the wick is adequate enough.
          Cheers,
          Cajun
          #220738
          Samuel Phelps
            Working on the carb now .
            I got a rebuild kit . Where do the plastic looking seals go ?
            #220740
            Samuel Phelps
              And how do you get the metal plug out of the slow speed ? needle casing ?
              #220761
                you punch in a small 1/8 hole with a drill but you just punch in DO NOT GO FURTHER then you take a small nail or pick and pry it out…. very easy job
                when done…. install the new plug what I do is take a squarehead (Robertson ) screwdriver #2 and punch the center (dome) of the plug with a light tap enough to mark it
                then I apply clear fingernail polish to seal the joint
                see utube on doing a carb on a 9.5 at 5:22 min. same principle
                https://www.youtube.com/watch?v=r-VTkOuSg00
                • This reply was modified 5 years, 12 months ago by JACQUES.
                #221338
                Samuel Phelps
                  https://youtu.be/Rs7I25bZ0dI
                  Got it back together .. Cleaned the tank and screen .. Really gunked up …
                  Used some 16-1 ratio fuel I had on hand . I assume 24-1 is correct for this motor ..
                  Only ran it a minute . I want to check/replace water pump/impeller .. Any tips on dropping the lower unit other than taking the bolts out and dropping ?
                  #221339
                  Samuel Phelps
                    I also need to find a slow speed needle valve stem and knob .. The old one is broken off on the end ..And a new fuel shutoff valve ..
                    #221384
                    Samuel Phelps
                      Ordering stuff for lower unit .
                      Item 23 is not present on my motor . I assume that seals the connection to the water tube and I should order it.
                      Also trying to get the upper screw out of the lower gear casing . Is it ok to use heat there to try and break loose ? The end of the exhaust is broken . Will this hurt anything to run it like that ?
                      #221385
                        I have some parts if needed.
                        1 914 310 7086
