Home › Forum › Ask A Member › Getting and keeping my 3 hp. Evinrude running?
- This topic has 5 replies, 4 voices, and was last updated 3 years, 7 months ago by
lindy46.
March 22, 2023 at 10:11 am #274282
I have a 3 hp. Lightwin Evirude that I got a couple years ago. Today I took it out and started it up. It took a long time to start, then finally did. But after a short while it no longer ran at higher speeds and shut down. I didn’t drain the gas over the winter though I did put in some gas additive. Is something plugged up? Why does it take so long to start when cold? What do I do? I’m open to all suggestions and remonstrance!
March 22, 2023 at 10:36 am #274283fuel flow may be restricted from the tank’s inner filter above the valve ,
the carb’s low speed circuit feeding fuel to the top drip holes maybe clogged…..
first thing to do is clean & rebuild the carb.. all orifices all passages and blowed with air pressure. (use a keyboard spray can if you have no compressor)
check for sparks… coils maybe all cracked under the fw. points can be usually cleaned and adjusted but condensers may be bad .
- replace the impeller if age or condition is unknown
all basic oldies revival stuff etc… etc… see articles
As a AOMCI member you could have downloaded yourself a copy of the 400 page + johnson red book… it is worth it !! if you plan servicing oldies
- MEMBERS ONLY tab
- INNER SANCTUM tab
- FIND LIBRARY
- Find.. GARRY SPENCER’S DROP BOX
- GO DOWN his list of files and find the RED Johnson Repair book file
- Download and print ( a local print shop can print and collate the book for you…. the book covers 3hp JWs
Outboard Motor Carburetor Repai (leeroysramblings.com)
http://www.leeroysramblings.com/johnson_magneto.htm
March 22, 2023 at 11:42 am #274289Thank you for the excellent advice.
March 22, 2023 at 12:42 pm #274291Check Crosbymans links for the details .
My first thought is cracked coils. Almost certain they are cracked if original. You should also clean the fuel system and check impeller and gear oil .
March 22, 2023 at 1:35 pm #274296Dang… forgot the gear oil 🙂 …. and always use new nylon washers
March 24, 2023 at 9:55 am #274346Was it running good last year? What maintenance have you performed on the motor in the 2 years you’ve had it? Have you checked compression? All good advice above. If those motors have compression, spark and gas they will start easy, run great and idle down to a putt-put-putt. I’ve had many and they are great motors and practically bullet – proof.
