Home › Forum › Ask A Member › Get a Grip
  • #265419
    Samuel Phelps
      Hey guys what’s the best way to take a grip off the handle and not mess it up ?
      First thing comes to mind is hot water ?
      #265423
        The wife’s blow dryer works good also.
          Dream up a way to push it off, rather than pull it off  (after you warm it up)
          #265436
          Dale
            Does your grip have a hole in the outside end?   If it does use some compressed air from your air compressor.   Place a blow gun over the hole and give it a blast.   We used to take motorcycle hand grips off like that.   Hang on to the grip ’cause sometimes it goes flying!
            dale
            • This reply was modified 4 years, 2 months ago by Dale.
            #265463
            Samuel Phelps
              Thanks guys , yes it does have the hole in the end . Never thought about using the air .. I’ll warm it up first and get a feel on how well it’s stuck on there . It’s in pretty decent shape so hopefully I don’t tear it up . Lol ! Are there replacements or alternative grips for the small grip that connects the 2 lower covers in front of the motor ?
              • This reply was modified 4 years, 2 months ago by Samuel Phelps.
              #265467
              Samuel Phelps
                Update: really hot tap water and a bit of soap did the trick . Is there any way short of painting to bring the whiteness back to the grip ?
