Home › Forum › Ask A Member › Generic gas line not pressurized
  • #276270
    sutterhome
      will all generic gas line like this one
      https://www.ebay.com/itm/324711324991?
      fit the standard non-pressurized motor and gas tank fitting?
      #276271
        at that price it is the kind that gets rock hard    after  some time      ….best to stick to the good stuff.
        #276273
        sutterhome
          but will it fit, just need it to test a Johnson 92 4 hp that I have to work on. Some of the connectors ends seem different depending whos selling
          #276275
            4hp connector on theengine is standrad    hose connectors needs to be  engine manuf. specific. …even if the look alike get  OMC stuff/evinrude/johnson
            I do not know if YAMAHA/Johnson  ?? hoses fit.
            if you just want to test the engine you can do a fuel ” blood transfusion”  directly into the carb to feed it  by gravity  🙂    save 20$
