Home › Forum › Ask A Member › Generator for 1959 35hp Gale Buccaneer
- This topic has 21 replies, 7 voices, and was last updated 6 years, 12 months ago by
David Stanton.
November 8, 2019 at 6:22 am #186708
Hello,
We have a new old stock remanufactured OMC generator for sale.Thanks,
Joe
(770) 597-5992-
This reply was modified 7 years ago by
mercuryspecialist.
mercuryspecialist.
November 8, 2019 at 6:25 am #186712November 8, 2019 at 7:21 am #186716Thank you very much for these part diagrams, Frank. Extremely useful.
DavidNovember 8, 2019 at 7:23 am #186717I am interested in purchasing this generator. I will call today.
Best regards
DavidNovember 8, 2019 at 8:10 am #186721Hi David,
You are welcomed to call, but as I see that you are from Canada, if you should like to e-mail, please do feel free. If you should write with your mail code, we can also quote mailing.Thank You,
Joe
info@fergusonpoolemarine.comNovember 10, 2019 at 11:36 am #186865I have never seen a 1959 Gale Bucannes 35HP with electric start, other than the Sovreign model. The regular Buccaneer 35 was only pull starts as far as i am aware, but could be worng. That is why there would be no cogs on the flywheel for the generator drive. Any flywheel from a 1961 or earlier 25,35,40 should work. I likely have one if you need it. The generator bracket would need to have provisions for the gale style hood mount to be attached. I would have to look at some part numbers o be sure what motors could provide the correct bracket.
Gale offered 35s with electric start every year they were made (1958-1960). Same for the 25s made before that. I have a 1958 35 with electric start. The model numbers had an E added in the middle of it.
Dave-
This reply was modified 6 years, 12 months ago by
David Stanton.
November 10, 2019 at 11:54 am #186871Yes. The model number of my motor is 35DE12B
November 10, 2019 at 1:25 pm #186877November 10, 2019 at 1:35 pm #186880Well, then I guess I am wrong. Someone please help me with the exact model number. Mine is an electric start, 35 hp, 1959 Gale Buccaneer. The motor is in winter storage at the moment, so I am going on what I have noted in the past.
Thanks much.November 10, 2019 at 3:37 pm #186890Actually, it doesn’t make a whale of a difference if it is a Sovereign or regular Buccaneer. Pretty much the same thing. But now that we are “discussing” it, how did you determine it is a 1959? 1958 Buccaneer 35 electric start was similar except for the Sovereign trim. Also, are you sure it is a 35hp? Again, 25hp and 35hp are similar in many ways. Does yours have compression relief valves in cylinder head (35hp)? A running change in 1959 (35D11 vs 35D12) was the tilt lock on the stern bracket. 35D12 series had the type shown in the inset. 35D11 had the separate knob.
