Home › Forum › Ask A Member › Gear Ratio
  • #198544
    Dale
      OMC guys, does a 10hp 1956 five bolt gear case have the same gear ratio as a 1957 five bolt 18hp gear case? I am using a 10 horse gear case on a 18 and was wondering if I was making a mistake.
      dale
      #198547
        They are not the same. 15:26 for 10hp, 12:21 for 18hp
        #198559
          The ratio is pretty close, at 1.73 for the 15 and 1.75 for the 18. The question in my mind is will the smaller teeth of the 15 stand up to the extra hp?
          #198564
            Learned something today….Always thought the gears were the same….
            #198581
            Dale
              Thanks guys! Probably not worth changing as little as I am gonna run it. I have a 9X11 propeller for it. Another one for sea testing. Wish I lived on a lake somewhere. The right propeller should even things out.
              tks again
              dale
