Home › Forum › Ask A Member › gear case-matched set?
  • #270346
    outboardnut
      When replacing a gear in a gear case.Can a person just buy one?
      Or should a person purchase all of them.Are the gears a matched set?
      #270348
        It depends on the gearcase.  If the parts book lists part numbers for individual gears, then replacing them individually is fine. Needless to say, there are all sorts of traps to fall into here though.  Part number changes, supercessions, etc.  The other gears/teeth should be inspected closely as well, no sense in replacing just one gear if the teeth are worn on the other gears as well.
        Is there a particular engine/part number you are working with?
        #270351
        outboardnut
          How does one find out individual part number for each gear?
          1956 RDE-18 30 hp Johnson
          gear-case1956-30-hp-RDE-18-1
          list-gear-case-1956-30-hp-RDE-18-1
          #270360
            I had the individual gear numbers when I restored my RD-18 a few years ago but can’t seem to find it at the moment, except for the pinion gear and bearing assembly which is part #375835.   I’ll keep looking for the forward and reverse gear numbers.
            13-New-Pinion-GearBearing-375835
            1982 Evinrude 25hp
            #270371
            outboardnut
              Bob – How did you figure out the part number for the pinion gear?
              #270374
                When I was rebuilding mine, somewhere or another I found a breakdown of the individual gear set numbers.   I thought it was filed on my computer but I lost some files when my laptop crashed and burned a few weeks ago, as I can’t put my hands on it right now.   I’m still looking.  Since my last post I did find the clutch dog part number is 375783.
                1982 Evinrude 25hp
                #270399
                retiredoz
                  These are the numbers in my ’69 Parts Reference Manual for RDE-16 thru RDE-19 :  Fwd Gear 375759, R Gear 302517, Pinion 375835, Gear Set 375861  My ’79 Manual lists the same numbers, so apparently they weren’t superseded by then..
                  #270403
                  JOSEPH BRINCAT
                    My humble opinion … the gear sets in our antique and classic outboards are not sophisticated enough to have been manufactured in lapped -in matched pairs. So, with some reasonable consideration to replacing individual gears that don’t have excessive wear or broken teeth, should be no problem. Now this is likely not the case for modern large horsepower outboards.
                    #270405
                    outboardnut
                      retiredoz- thank you for the numbers. My 1964 Parts reference guide does not show individual gears.
                      I heard a LONG time ago that the forward and reverse gear are the same except for the inside bearing. So in theory a person could use a arbor press on the inside bearing and reverse the gears . What I am trying to do is gather up parts from various gear cases I have to make one.Through my research # 25 and # 36 roller bearings were used in a 1960 40 hp RDS-22
                      #270406
                        OK, I can also confirm the same numbers provided by retiredoz.    I finally located my file record on gear set numbers – see enclosed.
                        Gears-and-Gear-Sets
                        1982 Evinrude 25hp
