Home › Forum › Ask A Member › Gator Trailer Model and Year
  • #3796
      As I was sanding off paint on my Gator trailer frame today,
      I found the following stamped on the top of the frame……..
      W-214-1942
      I presume "214" is the model number, but I’ve seen other photos
      of Gator trailers that don’t look anything like mine that the owners
      say are model "214".
      If the "1942" is the year of manufacture, then it’s a lot older than
      I would have guessed. Also if it’s that old, I have to wonder if it
      has normal tapered roller bearings that I can replace.
      Any thoughts on the model designation or the year?
      Thanks.
      outboard315
        1942, Most likely not unless it was made for the war.
        #33171
          There’s dark blue / black under the two coats of yellow
          paint, but I assume that’s a primer, and not war paint!
          gdcarpenter
            These photos are questionably from a 1962 brochure. There was a 200 series and a 214 model. I would guesstimate that yours may be a bit earlier production since yours does not have the fancy schmancy fenders. I suspect mine was the 145 model.
              Thanks GD! Looks like the 214 Model simply designates it’s
              for 13 to 14′ boats. Wonder what the differences are in
              the standard and super winches? Will have to look at mine
              closer and see if there’s any clues.
              I guess then that the "1942" following my model number is the
              serial number. Would be interested in hearing from someone with
              a 214 of known year manufactured to see if my serial number was
              higher or lower.
              Thanks!
