Home › Forum › Ask A Member › Gasket Replacement
- This topic has 10 replies, 4 voices, and was last updated 3 years, 7 months ago by
JACQUES.
March 3, 2023 at 7:17 pm #273398
Old, but new to 50’s motors. Find myself having to deal with GASKETS. Two questions. Can one reuse gaskets? And, in my case, I ordered some new gaskets for a 54 Johnson 10 hp. Should I use gasket “goop” on the new gaskets as I install? I assume it’s a no-no for the head gasket…. but on the exhaust side??
March 3, 2023 at 10:47 pm #273402if you are talking base gasket under the power head…. I never gooped one myself.
March 4, 2023 at 12:39 pm #273427Except for head gaskets, I find that making new gaskets from sheet stock is a rewarding and enjoyable part of the hobby. Thinking back to my childhood, I don’t recall that I had a part in my sister’s paper doll cutting sessions, but maybe so. Like a lot of other aspects of our hobby, there are a few tricks and tools needed to do the job, but nothing magical.
March 4, 2023 at 1:38 pm #273428If you remove a powerhead or pull a cylinder head or exhaust cover, I’ve always thought that if you went that far, you might as well install new gaskets. I always use a gasket sealer on the powerhead base gasket and on exhaust cover gaskets but never use them on intake/reed plate or carburetor base gaskets. The cylinder head gasket always seems open to discussion – some folks use sealers and others don’t. Some head gaskets are even marked “use no sealer”.
"Every time you remove a broken or seized bolt an angel gets his wings."March 4, 2023 at 2:35 pm #273429Thanks for the tip. What “sheet stock” do you use? Do you use a gasket compound with your new cutouts?
March 4, 2023 at 2:43 pm #273430Thanks Bob,
I have been warned off using any sealer on the head gasket And sealer (high temp) can’t hurt on the exhaust parts. Unfortunately I have to reuse the gasket between the reed plate and the power head. I got an new one for the other side but it seems like cheap paper. I thought gaskets were made from cork or rubber.March 4, 2023 at 2:48 pm #273431Thanks Mr. Crosby Man. I never sealed that exhaust housing to motor one either. What about the leaf plate? I have to reuse one there.
March 5, 2023 at 12:07 am #273444no expert myself…
but I suspect no operational issus would come up if the gasket is installed dry and bolts are torqued to spec.
On the down strokes the pressure build-up in the crankcase is mostly, if not 100%, directed out the intake then to the outports to flush burnt fumes from the cylinders while the leaf’s would be pushed against the plates… very little pressure would make it out the gasket surface.
Conversly, on the upstrokes (vacum to draw in fuel) the leafs will open and very little if any air would sneak by the leaf gasket surface.
if not used in excess enough to block critical passages I do not suspect a touch of sealer would create problems so … go for it if you feel more confident
March 10, 2023 at 1:20 pm #273685uupdate… well I tried to install the PH on my CD this morning and got annoyed at lining up PH on a bunch of holes on gasket on the base so….
I added a few dabs of gasket maker siliocone … just a few …….and having it dry for now….
gasket is all lined up 🙂 should be a piece of cake now to install the PH 🙂
April 6, 2023 at 1:10 pm #274853Crosbyman, you mentioned in a post not long ago that you found a supplier for those Dash-107 O rings for the fuel connector in Oakville I believe. Grainger is out of stock in them. Can you help me with a source. I tried to PM you last night. Guess I don’t know how.
