Home › Forum › Ask A Member › Gas to Oil Ratios
- This topic has 10 replies, 6 voices, and was last updated 2 years, 3 months ago by
Don.
July 7, 2024 at 12:57 pm #288916
After a hiatus from the outboard motor hobby to focus on old wooden boats I find myself back with motors. Somehow the number multiplied over the year. (My wife has the same problem with coat hangers!). I am learning to love small horse power. Mostly it’s because I can lift them. Near the bench are three 3 hp Johnson JWs. The 1960 and 1961 have fueling instructions printed on the front recommending 1/3 of a pint of oil to 1 gallon of gas (US). That’s 24:1. (J4J). The 1967 JW22-C states 1/6 of a pint of oil to 1 gallon of gas. That’s 50:1. (J6J). What happened over those six years?
Thanks to many at AOMCI I have several 5 1/2 and 7 1/2 Johnsons and Evinrudes (1955 through 1958) humming away. The recommended mix is 16:1. Confused?
July 7, 2024 at 4:16 pm #288929
The oil got better and has to continued to improve.
Factory ratings changed over 50 years ago. Tubs
July 8, 2024 at 8:45 am #288936Thanks Tubs, I have that 1971 Service Notice. I will go forth with trepidation and use 24:1 for the early 60s and 40:1 for the 1967.
I also note that they recommend “Leaded” gas for all.
July 8, 2024 at 9:05 am #288939Just a little note here about the gas. Back in the fifty’s Kiekhaefer recommended using white gas, which is unleaded gas. Don’t know why but Elmer (Carl) always liked to be different! It does make spark plugs last longer!
dale
July 8, 2024 at 9:08 am #288941no more leaded gas…. on pre 60s oldys I use 25/1 1L oil /25L fuel twc3 ad cd qd….
up to you
July 8, 2024 at 9:53 am #288944I can learn new things. I’ll shake off that 16:1 urge for the mid to late fifties. But after so much work and so much help from the forum to get my 55 Evinrude 5.5 back to life…..well, I worry.
July 8, 2024 at 10:29 am #288947Thanks Tubs, I have that 1971 Service Notice. I will go forth with trepidation and use 24:1 for the early 60s and 40:1 for the 1967.
Read the asterisk that applies to your model
July 9, 2024 at 10:37 am #288995I can learn new things. I’ll shake off that 16:1 urge for the mid to late fifties. But after so much work and so much help from the forum to get my 55 Evinrude 5.5 back to life…..well, I worry.
OK, this perpetual discussion continues.
For sure, outboard oils have improved over the years, no doubt. The question is has the oil quality improved enough to lube those plain rod bearings adequately at a lower ratio? Perhaps on the 3hps.
But, on the 5.5s/7.5s, I don’t think so. I would always stick with the original 16:1 recommendation. The beauty of these old engines is that when in proper tune, they hardly smoke, even at 16:1. That rod set up is definitely the weak link to otherwise bullet proof engines.
What about the argument that “OMC even recommended lighter ratios on these engines using the newer oils”. I’m thinking most of those recommendations came from short time OMC staff/engineering/sales folks that had little or no experience with the 5.5/7.5 models. Keep in mind that it was probably the same type of OMC staff the promoted the 100:1 mix in the 80s, and we all know how that went.
July 9, 2024 at 5:08 pm #289003Back in “The Day”, I asked an Evinrude Engineer, face-to-face, about what changed to make older motors ok with 50-1. He said “sometimes, they just found out that their motors didn’t need as much oil as they thought they did”.
But is today’s oil better? Hey, back then you could go to your local gas station and buy used drain oil in glass bottles with a metal pour spout. It was sold as re-refined oil or something like that.
1970’s era was the start of the outboard horsepower race. They were making 140hp motors in similar size and weight as the old Fat-Fifty. Terrible timing, leaded gas was also being phased out. And high performance/high compression motors were busting pistons from pre-ignition and detonation caused by low octane gas. The lead was needed for the octane rating in those cases.
Cars too, I owned two high compression cars, a 110hp Corvair and a Pontiac Bonneville. The lead was needed for the octane. I had the timing set so far back in the Corvair that it couldn’t get out of its own tracks. But it still pinged even while going downhill. Both cars were sold because I couldn’t get gas for them.
July 10, 2024 at 8:37 am #289015
The models that are known to be prone to repeated connecting rod failure indicates a flaw in the design. Just adding excessive amounts oil can’t resolve that. I would suggest you use the best oil available and limit the time you run the motor wide open, if at all.
