Home › Forum › Ask A Member › Gas leaking from Carb
  • #5418
    dale
      I have a 1954 Johnson 5 1/2 HP model CD-11 outboard with a two-hose connection to the gas tank. While the engine is running, everything appears to be fine. But when I shut it off, gasoline starts pouring out of the carburetor until I release the pressure in the gas tank. What is causing this? Could the float in the carb be sticking or not adjusted properly?
      #45132
      jerry-ahrens
        Well, that should not be happening. Sounds like the float needle is not doing it’s job. I would recommend installing a complete carburetor kit from the dealer. It will come with a new float and a modern rubber tipped float needle. Aftermarket carburetor kits will not include a new float, so go with an OEM kit. We can give you the part # if needed.
        #45142
        dale
          Thanks. I will tear it down and check the needle. If it appears to be the problem, I’ll request that part number. Thanks. Dale
          #45146
            Dale
            Do you have a parts breakdown for the CD10?
            Let me know if you need it.
            Steve A W
