Home › Forum › Ask A Member › Gas disposal question
- This topic has 13 replies, 13 voices, and was last updated 10 years, 11 months ago by
sailor58.
December 11, 2015 at 3:36 pm #3150
Yesterday I picked up a FD-10. A 1956 15hp Johnson. Along with the motor came a pressure tank and line. Inside the tank is a full tank of gas. OLD. Probably ten or more years old. Any ideas on how to properly dispose of the gas?
BTW. The motor is an electric start!!!!! All for $75.00!!!
Merry Christmas to me!!!December 11, 2015 at 4:37 pm #28414Old gas works great for killing poison ivy.
Joe
December 11, 2015 at 5:08 pm #28415I run it through fine mesh strainer and mix it a little at a time to my lawn mower gas or to my old trucks gas tank.Done it for years no problem.
December 11, 2015 at 5:12 pm #28417Some counties have drop off sites, or yearly
collections at various towns in the county.Prepare to be boarded!
December 11, 2015 at 5:38 pm #28420I run it through fine mesh strainer and mix it a little at a time to my lawn mower gas or to my old trucks gas tank.Done it for years no problem.
^^^^^THIS.
Pour it through some sort of strainer and mix it with the fuel of anything with a carburetor. EFI engines can get a little more finicky about that sort of thing but it never stopped me! One time, I straight up poured 2 gallons of old premix into an almost full tank in my pick up truck. The ratio was about 20 gallons of E-10 and 2 gallons of old, nasty premix. My truck (1999 Silverado) never knew the difference and that was 20k miles ago.
Rob
Rob
December 11, 2015 at 6:20 pm #28421Yep, I have poured old premix in my gas tank and have never had a problem. Strain it first like stated above, and put some in just before you fill it up.
December 11, 2015 at 6:28 pm #28422I use the same paper strainer funnels that I use when mixing finishes.Get them at Napa for free as a regular customer.
December 11, 2015 at 6:30 pm #28423Call your local landfill, we have a hazardous waste drop off here. Our ground water can get polluted pretty easy. We can also put used motor oil in jugs out for pick up on trash day.
December 11, 2015 at 10:36 pm #28433I clean parts with old gas
December 11, 2015 at 10:46 pm #28434I tried using it a little at a time in an old Nissan car I have. Didn’t have any trouble for a while until I used 50/50 old gas mixed with new. I stuck a fuel injector open, and went through complete misery fixing it myself. A reman injector for that engine was $130. I will never put old gas in my vehicle again. But that’s just my humble opinion..
I give all my wast oil to a local scrap yard to heat his shop with, as he has a waste oil heater. He told me he likes having some gas mixed with it. It’s easier to pump and the heater burns it fine. -
