Home › Forum › Ask A Member › GALE BUCCANEER 5.0 HP
  • #7483
    joellerich
      I HAVE A GALE 1957 MOD 5D148, 5.0 HP THAT IS STUCK. I AM LOOKING FOR A REPLACEMENT POWER HEAD. I KNOW GALE MADE THESE ENGINES FROM ABOUT 1952 THRU 1958 AND SOLD THEM UNDER MANY DIFFERENT BRANDS. I AM HOPING THAT THE POWER HEAD IS INTERCHANGEABLE WITH THE VARIOUS BRANDS. DOES ANYONE KNOW OF A INTERCHANGEABILITY LIST ?
      SECOND CHOICE IS TO TRY AND UNSTICK THE ONE I HAVE. ANY HELP WITH METHODS OF FREEING UP THE OLD POWERHEAD WOULD BE APPRECIATED.
      THANKS
      JOHN
      #60679
        John, most likely your model is a 5D14B instead of 5D148.
        I believed the "B" designates it as a Buccaneer.
        Speigel Brooklure, Goodyear Sea Bee, & Sea King all used
        the 5D14 power head in 1957, and I’m guessing prior years
        would work. If you can find parts diagrams for the various
        years of 5 hp, compare the power head "base" gasket parts
        numbers. If they’re the same, good chance it would bolt up.
        I’m sure other’s will know more.
        A search for "froze up", etc., on the forum should bring up
        lots of threads on people’s favorite "stuck engine" therapies!
        Good luck.
        David Stanton
          First thing to do is determine why it is stuck. Do not assume a fried powerhead. Can you grab the flywheel and wiggle it back and forth at all? Often you can wiggle the flywheel some even if a rope pull feels like a solid stick. I’ve had this caused by seized lower unit gears, and related parts, even seized when in neutral, and have seen broken water pump impellers make them stick. If the flywheel will not move more than a barely detectable super small amount back and forth, it is likely one or both pistons are stuck. If so, determine if it’s one or both by sticking a long screwdriver in the spark plug hole until it touches the top of the piston – then try and rock the flywheel back and forth while keeping you other hand on the screwdriver to "feel" if the piston is moving at all. I recently had a 5-1/2 Evinrude, 1957, that I was able to determine had one piston stuck using this method. For stuck pistons/rings, as has been already said here, there are several methods of trying to free them up. I start by positioning the motor so the spark plug holes are straight up and then putting in a solvent that attacks corrosion like penetrating oil, liquid wrench, transmission fluid, or I’ve heard a lot of great things about Kroil freeing up pistons and rings. Once soaking, try to move the flywheel back and forth every few days – you may want to try moving it with a wrench on the flywheel nut just don’t put enough load on the wrench to unscrew the nut.
            Your 1957 Buccaneer is a 5D14 model. 5D12, 5D13 and 5D14 all use this same powerhead. . . 😀
            #60691
              "Unsticking" the powerhead may be successful if you are lucky. If not so lucky, you may get it unstuck only to have it throw a connecting rod soon after you start it up. That would be the result of water in the crankcase, causing both the sticking and destruction of the rod bearings.
              There are some differences in hood mounting brackets through the years, but should be the same across brands within the same years.
