Home › Forum › Ask A Member › Gale 5hp fuel pump.
  • #263475
    mercuryman
      Will the 0388685 pump made for 6hp,8hp,9.9 hp & 15 hp fit the Gale its looks like it will ?
      #263477
        It will bolt up ok, can’t say for sure about the orientation & thickness.  Probably ok.
        #263485
          The square pump can be disassembled and the inlet and outlet clocked to any position you need.
          omc_0393088-Fuel-Pump-Diagram
          #263602
            when placing the springs I add a small dab of crazy  glue to hold them in place on their  bases ….. same with the small mushrooms on top of the springs   … I glue them on the springs.
            that way nothing flies off to nowhere land .
