Home › Forum › Ask A Member › fussy on GC oils ???
  • #271282
      Marine GC  oil    946ml can now 25$  at Canadian Tire …. 🙁      for  cd ad td rd type of GC
      would any  75-90 garde oils be ok for a few runs in the summer…     it  gets dumped anyway  come autumn…
      75-90 grade oil is 25$  GALLON
      • This topic was modified 3 years, 9 months ago by JACQUES.
      #271317
      aquasonic
        I recall reading that marine grade gear oil should be used. The non-marine tends to build up more vapor pressure. At least that’s my recollection.
        Improvise-Adapt-Overcome
        #271326
          You make a great point indeed!  I never gave any thought to vapor pressure issues.  Needless to say, excess vapor pressure could overcome seals/orings/gaskets ability to seal.
          #271336
          need2fish
            Aside from the viscosity, I believe the more complex gearcase lubes need additives. That is, the larger gear (for cooling) and complex (for helical gears) oils require long-chain and low shear additives.
            #271370
              It has been said that GL5-rated gear lubes will “attack yellow metals,” which there is often a lot of, in OMC lower units. Sometimes I have run into OMC units that have had very severe wear to these bushings/bearings and I wonder whether that had anything to do with it, or not.
              #271372
                Thanks to all for your inputs….$25 it is …..but like many things in the last 2 years  I just felt abusive pricing  is creeping up is everywhere and  possibly unjustiable.
                the petroleum industry profits seems to support the trend 🙁
