Home › Forum › Ask A Member › Fuel Tank Decals – Confused???
  • #289463
    John Gragg
      Hi All,
      So I finally have gotten around to doing some work on my fuel tanks. I bought a set of decals for the 4 gallon tank from Discontinued Decals many months ago, and just last night thought about installing them.
      I didn’t realize the decals were a ‘sheet’ of lettering? I thought I was buying the lettering that would transfer to the tank, no?
      Does anyone sell the lettering as individual letters, rather than as a sheet?
      I got one side done (sort-of) but didn’t like the look. Am I over-thinking it?
      I plan to use the 2K clear coat over the top once I’m done if that matters.
      Anyone who has done this with any input would be greatly appreciated. I found the instructions very difficult to understand and follow. Seems they made them harder than they needed to be?
      Starting from square one now, need to order new decals for whatever I decide to do.
      Thanks!
      Best Regards,
      John Gragg
      RIverside, CA
      Just starting in the hobby, please be patient.
      48 Sea King 5hp GG9014A. Sold
      49 Sea King 5hp GG9014A
      48 Johnson TD20. Sold
      49 Johnson TD20. Sold
      54 Johnson QD15. Sold
      55 Johnson CD12. Sold
      57 Johnson RJE-19M
      57 Johnson RDE-19
      #289482
      ALBERT MOORE
        try AMERICANOUTBOARD.COM 410 822 1740 They may have what you need
        al
        #289483
        aquasonic
          I’m not sure why you would want individual letters etc. Having everything on one transfer keeps everything lined up and positioned correctly within the decal itself. With everything separated, installation sounds like a nightmare.
          outboarddecals.com uses 3M vinyl decal material and has simple instructions.
          Improvise-Adapt-Overcome
          #289486
          Fastwin18
            I think he is referring to individual letters on a single transfer rather than 1 large vinyl decal that is transparant inbetween letters
            #289487
                1 suspect he has little experience applying decals. Watching some you tube videos about applying large decals maybe helpful. You can cut the decal up to make it easier. Even into single letters if you choose.Tubs
              #289495
              John Gragg
                Yes, Individual letters rather than a ‘sheet’ of letters. I have applied plenty of decals over the years (muscle car restorations) and have not run into a situation where the original lettering (or decal, as such) was applied individually, but the reproduction was applied as a sheet. (one vinyl decal).
                It looks so ‘cheap’ to me. It ‘screams’ “IM NOT ORIGINAL”.
                In my perfect world, the white lettering, e.g. “Johnson” would come off the vinyl sheet and stick straight to the fuel tank, as it did back in 1954 (or whatever year).
                Just my opinion.
                John Gragg
                RIverside, CA
                57 Johnson RJE-19M
                57 Johnson RDE-19
                #289496
                John Gragg
                  Or, even better…
                  Someone would sell a stencil that could be mounted to the tank and used to spray the lettering in white.
                  Anyone out there have any experience making/manufacturing stencils?
                  It would need to have a moderately sticky surface to keep it up against the tank while spraying the white.
                  Yea, probably not an idea that would work for the DIY’er
                  Thanks!
                  John Gragg
                  RIverside, CA
                  57 Johnson RJE-19M
                  57 Johnson RDE-19
