Home › Forum › Ask A Member › fuel tank cleaning
  • #55236
    nali
      Not the first time I show it, but I did a fixture to clean a tank.
      Using simple things anyone may have around.
      A bit noisy, but after one night it was perfect πŸ™‚
      Now I use citric acid since I discovered it. More efficient than vinegar, and no smell.
      This is a 1952 Beaver saw guide.
      https://www.youtube.com/watch?v=sPVaLjj8_j0
      #55242
      davesko
        Wow I have to remember that. A lot easier and more effective than shaking the tank a few minutes every hour. Great idea
        #55245
        nali
          Just a drill, a clamp to fix the speed (not too fast) , a drum with sand paper to make the bike wheel rotate.
          If I remember, inside there was just soap and dry wall screws. They are sharp, and after a few hours they cut everything.
          The result was perfect ! πŸ™‚
          The tittle say it : for the lazzy.
          Show your setup ! πŸ™‚
          #55551
          bill-loveland
            You inspired me to tackle my tractor gas tank – alas, I didn’t have a second tractor to do it this way: https://www.youtube.com/watch?v=eVZvjdQT3ks
            so I hung it from the beams in my boathouse. One wash with ammonia, and now I’m working through four gallons of diluted cider and several pounds of old screws:
            nali
              Does this tank move ?
              I’d love to have a boathouse !
              But I suppose I first need a boat and a house near a lake πŸ™‚
              I had about 10 outboard engines till now, but still no boat …
              At least, I’m restoring a 1950 Beaver saw, so I’ll soon have all the tools needed to build one πŸ™‚
              #55659
              gofastgramps
                what do you use to clean aluminum tanks safely?
                #55691
                davesko
                  This was an aluminum tank. Soaked two days with ammonia and two days with apple cider vinegar, of course I had nuts and bolts in both shaking often. Then rinsed with methanol/alcohol and dried thoroughly. Tank is spotless. Dave
