Home › Forum › Ask A Member › Fuel Pump recommendations for Johnson FD 12 conversion
  • #275811
    DrummermanBob
      Will the Sierra 18-7350 Fuel Pump work as conversion pump for Johnson FD12 18 hp?
      #275813
        It would require an intake bypass cover with the correct fuel pump mounting holes.
        #275814
          I just completed a fuel pump conversion on my FD-12 and used the Sierra 18-7350 pump.   As Frank noted, you need the intake bypass cover from a 1960 or later motor, OMC part number 307477.   Some folks have also fabricated an aluminum adapter plate to use with the fuel pump in lieu of the factory bypass cover.
          1982 Evinrude 25hp
          #275818
            the plate over bypass   works ok  I’ve done a few , plate, nippled cover  intake manfifold  etc…  easiest will be a bypass cover with proper mounting holes  and 18-7350 pump
            #275846
            DrummermanBob
              Thanks everyone for your responses!!
              #275853
                don’t forget to plug the  air  supply  nipple behind the carb… !   and find a single line side  fuel connector  !
