Home › Forum › Ask A Member › fuel mixture
  • #7493
    mike n
      hello, i just need the correct fuel mixture for a 1962 johnson 10hp and a 1958 18hp.thanks
      mn
      #60740
      Leon
        #60741
        mike n
          thanks
          mn
          #60756
            A quart of oil to your six gallon gas tank . . . 🙂
            #60813
            John
                I think we went to the same school! 😀
                mike n
                  how about older qd engines with bushings instead of bearings
                  mn
                  #60825
                  David Stanton
                    quote wrenchero:
                    I believe the spec on the older QDs is 24 to 1. I use 20 to 1 in mine. Convenient to drop a quart of oil in a 5 gallon can for 20 to 1 and a bit more oil in those can’t hurt. When I put an old QD on my grandson’s hydroplane, I double the oil, using 10 to 1 because of the higher RPMs
