Home › Forum › Ask A Member › Fuel Line
  • #302200
    davidk
      What’s a good replacement for the fuel line that goes from the fuel fitting to the carb on a 1956 Johnson Javelin 30hp?  Would that be 5/16″?
      #302202
      RICHARD A. WHITE
        Split your double line and use one side… or 3/16 will work with a quality clamp.
        classicomctools@gmail.com
        #302204
        Aidan Smith
          I found that 3/16 works well, 3/32 (I think) seems to work well too.
          1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
          1955 Feather Craft Vagabond - 1956 Mercury Mark 55E
          #302212
          Dale
            Dave I would say that the 30hp needs the 5/16″ line.   It might be tough to get the 3/16 on those bigger fittings.  40hp motors use 3/8″ line.   JMHO
            dale
            #302215
              Here’s the carburetor off my ’56 Johnson 30hp which is the standard model (not a Javelin) and this carb uses 3/16″ fuel line.   I would assume your carb is the same as this one as the only difference between the standard and Javelin models was the cowling cosmetics.
              56-Johnson-Carb
              1982 Evinrude 25hp
              #302217
              davidk
                56-Johnson-Carb
                The other difference is that my carb is not as clean and shiny as yours. : )
                #302218
                  Well, if you’re replacing the fuel line you can always shiny up the carb too!! LOL
                  1982 Evinrude 25hp
