Home › Forum › Ask A Member › Fuel filters on suction side?
  • #274093
      Would the diaphragm fuel pump and carb work okay
      with a inline filter in the gas tank hose, assuming
      the filter stays relatively clean?
      The fuel pump and carb on this 1960 Scott 7.5 is
      integrated, hence a filter can’t be installed in between
      the two.
      There’s a tiny screen (like chainsaws) in the carb, otherwise
      there’s no other filtration. The only problem, the powerhead
      has to be removed to work on the carb.
      DSCN6469
        I don’t know any reason it wouldn’t work fine.
        #274108
          that is where water separators go.
          #274111
            Thanks guys!
              I used an in-line chain saw filter on my 54 Firestone 7.5 ahead of the motor & never had any issues.
              #274120
                On my McCullough 9, (almost identical-looking motor) there is an OEM fuel line connector of the small, bayonet style, that looks like it would also be a fuel pump….but it’s a filter. I would post a picture, but it’s taken apart right now.
                #274123
                  I ordered a couple of inline, 1/4″ barbed filters, advertised
                  as “motorcycle” filters. I would think they would do it.
                  I forget how many “microns” in filtration.
                    If the item you are installing has a screen inside it, it is meant for gravity fed systems.  If it has a paper filter, it is meant more for pump systems as found on lawn tractors. The screened one will work with a pump but it’s not such a good idea to use a paper filter in a gravity system.
                    Years ago I thought I was smart and installed an inline automotive filter in the fuel line to my 55 horse Chrysler. It didn’t work very well as the filter clogged up killing the motor. The tanks were fairly clean so I think the element inside was so fine it wouldn’t let the oil in the mix pass through. Not sure.
                    #274202
                      Mumbles, I have to think that the filters I ordered are some kind of
                      paper element, but not sure. It does say that they are 60 micron
                      filtration, which according to a conversion chart, is just a little
                      over .002. That could be a problem.
                      https://www.ebay.com/itm/394423150566
