Home › Forum › Ask A Member › Fuel Connector Pic’s for Steve’s Daughter
  • #7330
    bill-m
      Hay Steve, here is the requested picture of the Clinton fuel connector. It has a half inch O.D. and is two and a half inches long. I hope your daughter has good luck in finding one.
      #59692
        Bill M
        Thanks for the picture. It will help in the search.
        Steve A W
        #59693
        ed-sam
          On these clip connectors the "O" can be replaced for perfect sealing. Good luck hunting. Ed
          #59710
          JOHN D.
            There was a place that sold the original Clinton parts but you had to call them. It was Certified parts I believe.
            You might try this site;
            http://www.aircooledenpts.com
            His site is called Jim’s old engines.
            I haven’t done business with either, just trying to help.
            #59749
            1-old-outboard
              Okay, so recently found out what my motor is and everyone has been a help so far.
              I’m stumped though, I got a primer bulb, some line, and a tank. But the connection to the motor is awkward… see my picture … where can I find the right "fitting" for this?…
              retiredoz
                Looks like a McColloch 7.5. Takes a Scott or small Merc fitting. I got both
                #59753
                  From the looks of the pitting, you might be better off fastening a short piece of hose to it with a common OMC connector attached and use easy to find OMC hose connectors. . . 😕
                  #59754
                  1-old-outboard
                    My motor is a McCullough, ted Williams sears see picture … can you fwd me a link for this fitting? Or am I buying it from you?
                    retiredoz
                      Sent you a PM
