Home › Forum › Ask A Member › Friction Washer Material
  • #3644
    viking66
      I need to make a Friction Washer for the handle on my 1950 Speeditwin. Is there a material that someone can recommend I use to make one out of?
      I have 2 extra from the main tilt support but they seem just a bit small in diameter because I have to have a elongated hole in it for the pin. If I use one of those it would put the edge of that hole on, or very close to the edge of the washer.
      Any other ideas? ❓
      #32027
      George Emmanuel
        I use black delrin and machine it from a solid round in the lathe.
        #32030
        david-bartlett
          I need to make one of these as well. I will wait and see what others recommend.
          #32032
          chas56x
            Leather.
            #32042
            viking66
              Leather sounds easiest. I have some laying around. I will give it a try.
              #32052
                I have used either a brass washer or carved one from sheet nylon, when I didn’t have the original.
