Home › Forum › Ask A Member › For Parts or Restoration
  • #200986
      • This topic was modified 5 years, 8 months ago by Tubs.
      #201001
        Tubs, neat looking little motor. Are you implying the crankshaft has a little
        bend in it, and that’s why the flywheel is catching on the mag plate?
        Dale
          Ok Tubs, what year is it? Think your weld will stay on the carb? Expensive bent crankshaft! I can relate to that. Probably cost more to return than what you paid for it. Sounds like one of my deals. Win some and loose some!
          dale
          governor opened up boating around here! yipie!
          #201006
            #201010
            Dale
              You know what happened to the crankshaft! Somebody tried to get it off with a claw hammer! A fella with your talent and a couple V blocks, a little bump in the right spot and she will live again.
              dale
              #201034
                • This reply was modified 6 years, 6 months ago by Tubs.
                #201200
                  #201202
                    Alumi-brazing works good for some things, and very frustrating
                    on areas where you melt out you first repair working on
                    an adjoining area.
                    Good save on that carb!
                      #201721
                        Rubber Baby Buggy Bumpers may have worked, by hard to find now days, lol.
                        I like your drill bit set…. so much easier than getting out the micrometer
                        or calculator!
