Home › Forum › Ask A Member › FONT SIZE
  • #5901
      How do I change the font size? I tried large and huge but it always show up as normal.
      Steve D
        Hey Bob, There are a couple ways to do it but the simplest might be just click on the font size you want first, and then just start typing because the cursor will already be between the brackets where you need it to be to get the desired size.
        #49232
        CHUCK
          Right. Otherwise you can type your stuff first and then highlight it with your mouse as if you were going to copy or cut it…..and then click on the "Normal" arrow in the tool bar and select "LARGE"
          I happen to like the larger font size.
          #49240
          kerry
            I also like the larger font size. Just wish I could set it as a default setting so I didn’t have to choose it everytime.
            #49247
              I do also.
              #49249
                Me too Kerry, My eyes are failing me.
                #49267
                  Maybe they will change the default to large as part of the website update. Bob
                  #49274
                  Steve D
                    Hey you did it Bob! Good for you!!
                    #49285
                    david-bartlett
                      like this?
