Home › Forum › Ask A Member › Folding Lightwin, seized upper driveshaft splines
  • #202265
      after the powerhead is removed with the shaft ,now is the time to use the air hammer
      Yes indeed…Should be able to air hammer that driveshaft down and out without ruining anything once the powerhead is off….
      #202336
        use the air hammer side to side near the crank. I use WD40 along with the hammer.
        #203050
          Got back to this project for a little bit today and learned some stuff….Knocking out that lower pin surely did allow me to remove the powerhead/seized driveshaft. Once off the exhaust housing, I learned the driveshaft was not seized to the crank! There is a roll pin just underneath the upper splines like on the 5.5-7.5hp models. There is a slot in the exhaust adapter plate like the slot found in the later 6hp models that requires the driveshaft be lined up correctly so the roll pin can slip down through the exhaust adapter. The powerhead was a bit stuck, but it freed up easily. So, this project can move forward….
          #203069
          David Bartlett
            Don,
            Good news. It is great to have a project or two during these crazy times.
            David Bartlett
            #203080
              I’m kind of excited about it, never had any experience with a folder. The gearcase on this one is busted up, but I have another one, so just need to swap the driveshaft. Not the nicest physical specimen, but OK…Will have to keep an eye out for a case….
              #203093
              GARY
                They are really handy little outboards.We take ours camping with one of our small boats or as a back-up on our larger boat.They stow in a small space and in the case,leave no unwelcome grease spots.
