Home › Forum › Ask A Member › Flywheel Torque Needed
  • #1879
      Does anyone have the torque value handy for the flywheel nut on a late 80’s or early 90’s 20 horse Evinrude? This motor has the under flywheel power pack and the threads are 5/8 – 18. Not sure if it has the built in rev limiter or not. Thanks in advance!
      #19069
      grover
        I have a service manual for 1980 25 & 35hp; that called for 100-105 ft-lbs.
        #19071
          Yeah, I’m pretty sure that’s what it is.
          Thanks Larry!
          #19086
            I opened up my OEM Manuals for that model and they state 105 ft/lbs as well.
            They also state to use OMC Gasket Sealing Compound on the threads! I have never done that before, nor read it before. Anyone else?
            #19088
              I have read that, but would ignore the advice, would be too easy to get sealer on the crank tapers.
              #19103
                quote Chris_P:
                Most of the newer manuals say that. I don’t know if it is for a thread lubricant, or a locking agent, or both (?) Old manuals don’t say that and I only work on old motors so haven’t been concerned. But anybody know for sure?
                #19202
                johnyrude200
                  I’ve had to upgrade to an OMC flywheel puller and beefier torque wrench/break bar setup to start working on the newer motors from 1977 and up. Anyone care to explain why a 1976 model 25hp needs only 40-45 ft-lbs or torque, whereas the bigger block now calls for 105 ft-lbs? I managed to pull the flywheel off an ’86 25hp model using the wimpy harmonic balancers you find at any automotive store, and doing that once was enough to say the least.
                  I just picked up an OMC flywheel puller – where should I pick up those 3 bolts for the tool (it was a salvage from a long closed dealership). It did not have the flywheel holding rod either, any recommendations for a good substitute?
                  I may be posting a few pictures of some OMC special tools that I am trying to identify from this lot as well.
                  #19203
                  david-bartlett
                    Joel,
                    McMaster Carr has shoulder bolts that would work. I’m sure you could find a piece of round stock somewhere for a handle. The bolts I linked are similar to what is in my set. The handle is just 0.5" round stock, 10" long.
                    http://www.mcmaster.com/#91259A587
                    http://www.mcmaster.com/#91259A632
