Home › Forum › Ask A Member › Flywheel Removal
- This topic has 10 replies, 9 voices, and was last updated 2 years, 10 months ago by
green-thumbs.
January 6, 2024 at 3:53 pm #283731
I am trying to remove the flywheel on a 1957 Johnson 35hp Seahorse. I bought a Bolt wheelpuller set at Harobr Freight, but that set does not seem to have three (3) bolts that are the correct fit. Any advice will be greatly approieciated. Thanks.
January 6, 2024 at 4:23 pm #283732try a 1/4 20 tpi if the bolts you have are to big
DO NOT screw the bolts down to far otherwise they will hit ignition components . I use reversed nylon nuts as stoppers
and they keep me from searching for the bolts in the bin box. 🙂
January 6, 2024 at 5:21 pm #283735I don’t recommend these pullers for flywheels on these larger engines. It is always best to use the OMC flywheel puller kit, much stronger. Using lesser pullers can result in broken bolts, and injury.
January 7, 2024 at 9:50 am #283746The best.Search OMC flywheel puller.
January 7, 2024 at 10:33 am #283749Prior to owning the OMC Universal Puller, I had a Harbor Freight harmonic balancer puller. The puller did not come with the 1/4-20 bolts that are needed for the smaller OMC motors. Had to buy the bolts and washers.
Besides the depth of embedment, it’s also very important that the bolts are embedded to the exact same depth. crosbyman has a good idea with the nylon stops to achieve this. It’s easy to strip threads on a stubborn flywheel when the bolts are not even.
The OMC puller has some awesome shoulder screws that when installed properly keep the puller exactly even. The measurement from end of screw to the shoulder is 13/32″ which would be a good dimension to set your stoppers at.
Fleetwin brings up a good point about the quality of the tool. Larger motors have more torque on the flywheel and therefore put more stress on the puller/bolts. I would assume that the H.F. puller is made from pot metal. The OMC tool is very well made.
Improvise-Adapt-Overcome
January 7, 2024 at 11:11 am #283750Anonymous
I’ll try to post a picture of my puller bolts.
I used shrink tubing on my bolts.
It works pretty good.
Sorry, can’t post the pic, it’s too big/January 7, 2024 at 11:15 am #283751Anonymous
can someone tell me the size allowed for pictures?
January 7, 2024 at 12:15 pm #283752
January 7, 2024 at 2:14 pm #283755I email my pics to myself using Outlook. The gui asks if I want to keep or reduce image size. I choose reduce and get good quality pics sized way down for our site. Just my experience
John Gragg
RIverside, CAJust starting in the hobby, please be patient.
48 Sea King 5hp GG9014A. Sold
49 Sea King 5hp GG9014A
48 Johnson TD20. Sold
49 Johnson TD20. Sold
54 Johnson QD15. Sold
55 Johnson CD12. Sold
57 Johnson RJE-19M
57 Johnson RDE-19January 7, 2024 at 7:40 pm #283768I go to my local hardware store and buy Allen-head shoulder bolts. I have more trouble finding appropriate washers.
