Home › Forum › Ask A Member › Flywheel puller for mark 5
  • #6308
    cheetahgod
      I’m having trouble removing the flywheel. I built a custom flywheel puller however the threads in my metal plate broke. Any suggestions on how to find/make one?
      #52690
      green-thumbs
        L
        #52725
        cheetahgod
          The threads on my crankshaft are not damaged. Its the threads on my makeshift flywheel puller.
          #52772
            drill your tool to let the bolt go thru. then use a nut under the plate. that way it can be replaced at any time. you will need 2 wrenches.
            #52794
            Doug Wilson
              Would agree with Dave on that one should work fine
              Doug
              turned off?
              #52803
              mercuryman
                https://www.amazon.com/TruBuilt-Automot … ear+puller
                $14.25 Amazon
                #52820
                jpatti75
                  Or make yourself a flywheel knocker. Works great for small motors. See this old thread which includes pictures and instructions:
                  viewtopic.php?t=6119
                  JP
