Home › Forum › Ask A Member › Flywheel magnet remagnetizing
  • #285403
    Richard Stuber
      I have a 57 Johnson 35HP RD19 that I can’t coax a spark out of after having replaced the coils, points, condensers, and plug wires.  How to I determine if the flywheel magnet is sufficiently strong?  Can it be remagnetized if weak?  Flwheel shows signs of former heating and hammer blows.
      #285404
        Magnets made after WWII just don’t go bad. Period. Look for something else.
        #285410
          just  approaching a screwdriver  close to magnet will  snap it place…. like FR indicated… magnet s are ok
          #285411
          PM T2
            Make sure the points are connected to the correct coil. Its easy to mix them up, especially if you changed everything on t he mag plate.
            Best,
            PM T2
            #285418
            elgin2
              Make sure the eccentric screw is working. Some new points have a hole too large for it to work properly.
              #285421
              reivertom
                Check the ground as well.
                #285424
                  burnish the points  and  clean with  acetone or alchool  on a strip of paper
                  #285425
                  Richard Stuber
                    Thanks for all replies especially assurance that magnet is okay and ho to verify that.   I’ll check wiring again carefully and report back.
                    #285426
                      did you perform a resistance test between the plug boots and frame ground to confirm all is ok     each coil should read  between 4-8 kohms approx. depending on manufaturer
                      did you adjust timing per this video
                      http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
                      condensers  are tricky  and may…. be bad  even new ones .  you can do  a “basic” test for  shorts  or open but the real  leak test is  done   with high voltage  (250vdc +)  if you  have  testing eqpt.
                      the western region AOMCI has excellent articles by m.Mohat
                      see articles 1-4 on condensers … how to test  and   fixes
                      #285445
                      Richard Stuber
                        Disassembled everything today and started from scratch following Seloc Volume II from pp 5-5 through trouble shooting and final assembly pp 5-25.  No fire yet.  Have watched the video per crosbyman and will give that a whirl tomorrow.  Condenser capacitance measures nominal but I am not equipped to test for high volt breakdown.  Can try a change out for good measure as necesssary.
