Home › Forum › Ask A Member › Flywheel magnet charger
  • #265657
    fastjohn
      Does anyone have one of these for sale ,or can I borrow one from someone?  I have heard that some people have been successful in mounting rare earth magnets in old flywheels.  Anyone have any experience doing this?  Thanks
      • This topic was modified 4 years, 2 months ago by fastjohn.
      #265695
      JOSEPH BRINCAT
        Your best bet on getting to use / borrow a charger is to network with your local chapter. If you are lucky someone may have a charger that either you can use or more likely will charge a wheel for you.
        #281535
          I just saw you post. I have a flywheel magnet charger and have for close to 40 years.
          I have learned that even though the pre war motors loose much of there magnetism over
          time it doesn’t effect how a motor starts or runs. Most of the pre WW-II motors out there
          have never had their magnets recharged and they start and run just fine. In the video
          below I’m firing a old coil from a Bendix mag. I never recharged the tiny magnets in
          that flywheel. In spite of the greatly reduced magnetism the coil works fine.
          However if you want to ship me your flywheel I’ll be glad to charge the magnets for you.
          As your having problems with PM you can email me at old.days@yahoo.com
          Tubs.
          https://youtu.be/71W9cPMV09A?si=vWCJXN7Vd0S-CSir
          #281553
          John Gragg
            For a short time I was almost convinced I needed a magnet recharge as well. One of our members asked me to do a test by putting a large, heavy screwdriver about an inch or so from my magnet. ( Sea King, magnets in the rotor, not the flywheel.) The test is will the magnet pull the screwdriver 3/4″ or more.
            I did the test, then tested how far it would pull. If I remember right, I was able to move the screwdriver 1.25″ away!
            Then I hung a bunch of tools from the magnet, no need for a recharge!
            That said, for all I know you’ve already done all this and actually need a recharge.
            Pics below are my experience, your mileage may vary.
            Good luck,
            Best Regards,
            John Gragg
            RIverside, CA
            Just starting in the hobby, please be patient.
            48 Sea King 5hp GG9014A. Sold
            49 Sea King 5hp GG9014A
            48 Johnson TD20. Sold
            49 Johnson TD20. Sold
            54 Johnson QD15. Sold
            55 Johnson CD12. Sold
            57 Johnson RJE-19M
            57 Johnson RDE-19
            #281556
              no expert on magnets but to answer your question    have you tried remagnetizing your FW magnets   just  by transferring the magnetism from one of those rare earth magnets.  No need to glue them on your fw
              I remember my father  magnetizing his screwdriver   tips  just by rubbing them on a magnet  a few minutes  using  a simple old style  ” horse shoe ”  magnet.
              These rare earth magnet are  so strong  today  they will  bite a finger if not carefull .   Some of them you can’t  even pull them apart unless you  slide them sideways.
              these small ones (bars) are  extremely strong and if you orient them correctly I would not be surprised to see them  load up your fw  like a charger.
              Method 1: Using Another Magnet
              To remagnetize a magnet using another magnet, follow these steps:
              1. Choose a stronger magnet that is similar in size and shape to the magnet you want to remagnetize.
              2. Place the weaker magnet near the stronger magnet, with the opposite poles facing each other.
              3. Slowly move the weaker magnet towards the stronger magnet until they touch.
              4. Hold the magnets together for a few seconds, then slowly separate them.
              5. Repeat the process several times, gradually increasing the distance between the magnets.
              Grtard 4Pack Neodymium Magnet Bar, Powerful Bar Magnets, Magnet Strips Heavy Duty, Strong Rare Earth Magnets with Double-Sided Adhesive for Craft, Fridge, Kitchen, Office – 60 x 10 x 3 mm : Amazon.ca: Industrial & Scientific
              #281558
              fastjohn
                Crosbyman,  Thank you for that info.
