Home › Forum › Ask A Member › Floatation advice for 14ft aluminum boat.
  • #1553
    cajuncook1
      Hey guys, looking to make a modification to my 1982 14ft Monarch Modified Vhull boat. I want to remove the floatation foam out of the middle bench and use it for storage, but I don’t want to sacrifice safety either. My aluminum boat is factory still.
      – Is there a way to add floatation material to other areas of the boat to maintain safety? I am also going to add flooring to the bottom of the boat on top of the support ribs.
      Thanks in advance for your advice and time.
      David T.
      #16535
      chinewalker
        Sure, add some foam blocks between the ribs when you lay the floor down. Leave room to allow for drainage at all rib weepholes. Only downside is that by moving the flotation lower, if the boat were to swamp, it may want to turn turtle…
        #16551
        cajuncook1
          Thanks Chinewalker for information. When you say, want turtle, do you mean flip over?
          #16560
          david-bartlett
            Yes! Turn turtle = upside down.
            #16562
              If you go with foam make sure to use the closed cell stuff and not the open cell foam. Open cell will absorb water like a sponge.
              #16594
              Casey Lynn
                And eventually the foam will start to compress and shred with each little bump the boat hits, leaving little pieces of foam to travel back and plug up your drain hole.
                #16598
                cajuncook1
                  Pappy are you referring to open cell or closed cell foam??
                  #16607
                    I think Pappy is referring to the white bead board.
                    We’ve got a ’70s something Starcraft that has the bead board gone bad.
                    It is due for new floor boards, We’ll eventually get it all done.
                    Use the blue or pink insulation boards from the big box stores.
                    Good Luck with Your boat.
                    Steve A W
                    #16623
                    cajuncook1
                      Thanks Steve, that makes sense now.
                      Cheers
