Home › Forum › Ask A Member › Float drop measurement for 1967 33 HP Johnson
- This topic has 7 replies, 7 voices, and was last updated 4 years ago by
Tubs.
October 22, 2022 at 11:59 pm #268054October 23, 2022 at 6:39 am #268058
I have never checked it, that I can recall. I just assumed they dropped until they hit the bottom of the bowl. I am probably wrong about that.
October 23, 2022 at 9:06 am #268064I’ve usually seen it the other way around – with the carb body inverted, the float should be level with the carb body. I’ve always adjusted the float this way and never had any problems.
"Every time you remove a broken or seized bolt an angel gets his wings."October 23, 2022 at 10:19 am #268069Likewise what billw and bobw said. As for the drop, I just eyeball it. Good ’nuff
October 23, 2022 at 4:04 pm #268123I have never understood the purpose behind a float drop adjustment. Why would it matter? Assuming that the bowl was not deep enough for the float to drop so far that the needle could fall out…….
Someone please explain please?
October 23, 2022 at 4:42 pm #268126must be spin off from the merc carbs….
as long as my toilet bowl ball rises and shuts of the water I don’t care how deep it drops 🙂
October 23, 2022 at 5:17 pm #268127must be spin off from the merc carbs….
That’s basically where I got the idea regarding a second measurement, after the first measurement for the float being level when held the other way. I always set up my 71 135 HP inline Merc using the procedure below.
I guess I’m overthinking OMC basic carb setup procedures.Bob D
October 24, 2022 at 10:50 am #268181I have never understood the purpose behind a float drop adjustment. Why would it matter? Assuming that the bowl was not deep enough for the float to drop so far that the needle could fall out…….
It occurred to me that possibly it’s to keep the float from laying on the bottom
of the float bowl as the gas dries up while the motor is not being used, especially
through the winter. The float could get stuck on the bottom? Just guessing.
