Home › Forum › Ask A Member › Fixed high speed jet removal tool
  • #17610
      The secret to the correct tool is the flat sides are parallel to each other. not tapered as a common screwdriver are. Tapered flats tend to spread the jet’s slot, making it tighter than ever. Yes, I used to make them but discontinued because it is surprisingly difficult to make a screwdriver. Especially since I discovered the one shown by Cajuncook. I forget at the moment where I got those (McMaster.com ???)
      #17613
      Steve D
        I didn’t see the tool on your website Frank so I figured you did stop making them. I know you often refer guys to McMaster Carr so I went there and that’s where I found the bits. Thanks!
        #17621
        William Jatzek
          What kind of engine and year of engine is this tool for?
          #17634
          Steve D
            At the moment these are the 3 I have that I can use it on…69 J-25, 70 J-25, 74 E-25
            #17660
              quote Billy J:
              Any of the OMC fixed high speed jet carb’ed motors. there are many!
