Home › Forum › Ask A Member › Firestone/Scott gear foot diagram?
  • #55667
      oltimer
        Yes Frank I did have the 1948 Motor file. I just did not think past the Firestone name which you did. Thanks for putting it up for David.
        #55708
        thumper
          quote Buccaneer:
          Thumper, I emailed the Scott guy the other day
          regarding an impeller.
          He replied, and his sentence parsing seemed
          okay, so maybe still among the breathing?
          I believe his son is still doing the impellers but that’s about it
          #55717
          oltimer
            quote Thumper:
            quote Buccaneer:
            Thumper
            What was your model #, so I can be sure on this item.
            #55718
            thumper
              Firestone 1952 10hp Serial #1825 309 Model 10-A-75 Code133-2-1825 Need impeller but have no part #
              #55720
              oltimer
                quote Thumper:
                Thumper do you have the old one for size? And does it take an eccentric cam in the middle of the impeller to drive it, or wobble it? I have a bunch that got dumped and put back in wrong part boxes before I got them. Or does it take the regular 6 blade impeller, and what size is your shaft, and casing inside width it goes into? I am sure I have it, but we have to work together a bit on this.
                #55732
                thumper
                  Here is the info
                  6 blade
                  ID 0.495 inches, 1.845 inches od, 0,567inches thickness
                    Aren’t these Honda impellers the ones you need?
                    viewtopic.php?f=2&t=11172&hilit=honda
                    I just got some from China for around six bucks each and with free shipping! The same impeller won’t leave much left from a $50 bill at the dealers.
                    http://www.ebay.ca/sch/i.html?_odkw=Mou … -&_sacat=0
                    #55738
                    oltimer
                      Thumper and Jim
                      How many would you like to get? Lol Got the newer double blade (later model) of the model in stock. The rubber on these is like they were made yesterday and very supple. The # on the parts box: 3785-5100
                      #55753
                        That’s a good part number Jer! I did buy one with that P/N for my ’56 7.5 but it was the single blade style. If the imported ones don’t work for the bailer side, I’ll be calling you.
