Home › Forum › Ask A Member › Firestone 1950 5hp Spark Plugs
- This topic has 9 replies, 4 voices, and was last updated 11 years, 5 months ago by
Buccaneer.
May 23, 2015 at 11:53 pm #1587
Can anyone tell me the original spark plugs for my 50 Firestone 5hp?
The oldest spark plug chart I have only goes back to 1955,
and I don’t find that information in the Scott manual either.
Thanks!Prepare to be boarded!
May 24, 2015 at 12:10 am #16743The book sez, Champion H-10J set at .035".
May 24, 2015 at 1:46 am #16758Thanks Mumbles, I’ll see if I can find the modern equivelent.
May 24, 2015 at 3:14 am #16766H-10C are still readily available.
John Van
May 24, 2015 at 3:15 am #16767H-10C are still readily available. That’s what I use.
John Van
May 24, 2015 at 1:14 pm #16783Good to hear about the plugs being available John.
Not sure what the difference is / was on the C vs. J suffixes,
but probably minor.
May 24, 2015 at 2:11 pm #16784The C plugs have the ground electrode extend all the way across the center electrode while the older style J plug ground electrode extends halfway across the centre electrode. This gap design requires less firing voltage at high RPM and also protects from ingested particles and carbon deposits wedging between the gap and shorting out the plug.
May 24, 2015 at 3:37 pm #16787My little 80 Yamaha motorcycle back in the 70’s could have used
a "J" plug……. always getting carbon chunks stuck in the plug.
Sometimes it would go "sputter, sputter, sputter……. BANG!",
and I’d be on my way again, but usually I’d be cleaning the plug along
the road to get home.
I believe Frank? mentions filing plugs to turn them into "J’s".
Thanks again Mumbles!Prepare to be boarded!
May 24, 2015 at 3:39 pm #16788Mumbles & Buc,
I am looking forward to getting a 10hp Firestone! Not here yet but soon. A 7.5 Firestone was my first motor & still own it. The ten will be a wonderful addition & enjoy it. Mine is a 1952 I believe. I’ll fix it up real nice to run all the time. Enjoy your motor too. They had Mercury in their sites as they were fast too. I won’t abuse it but up on plane & a little more for fun!!!May 24, 2015 at 9:16 pm #16796Jeff, the 10 hp Firestone sounds sweet. How does the 7.5 shift?
I’m already worried about my 5 hp. It definitely won’t shift "not running",
but hope it shifts when it is running!Prepare to be boarded!
